Buda rod question
Will
12-24-2003 12:27:37
What is the rod lenght center pin bushing too center rod end?
Irv
12-25-2003 13:56:29
 Re: Buda rod question in reply to Will, 12-24-2003 12:27:37
Will, acording to my measurements it would be about 7.375 which falls right in with the measurements John gave you! The rods in the Buda 153 gas and diesel as well as the 230 and 273 gas use the same rods, bushings and pins! The casting #'s are Buda B141A on one side and B Atlas 6 on the other side which John asked for so he can verifie this. need any thing else let us know Irv
Will
12-24-2003 20:29:00
Sorry, 153 Buda.
J. Schwiebert
12-25-2003 12:52:07
 Re: Re: Buda rod question in reply to Will, 12-24-2003 20:29:00
Since it is the same rod as a 230 and several others. Center to center distance is listed as 7. 373-7. 377. Are you working on a diesel? If so some of them have a different set of dimensions because they were made to take Military Standard rod bearings. Questions?
J. Schwiebert
12-25-2003 08:35:44
Do you have one out. I am looking for the forging number stamped in the rod.
J. Schwiebert
12-24-2003 18:10:49
Get me a Buda Forging number and I will check my AERA connecting rod manual.
old
12-24-2003 15:25:58
A lot of engines in the Buda where IH engines, I have a buda mule that has an H farmall in it
Larry from MD
12-24-2003 14:03:32
Depends on which engine.
