Looking for HP ratings
Jeff
12-24-2003 07:33:59
Although I know that in real use you can't always go by the ratings I am curious at the HP ratings of the 1500-1900 and the 50 series as well. I have a book that shows the ratings of the 1800 and 1900 but non of the others. Recently bought a Oliver252 disc and was kinda wanting areal green tractor to pull it with instead of these Deeres around here. I was told that a 60 hP tractor at least would be best but I am not sure what sizes that would be.
My son told me about the local dealer having and Oliver 76? grain drill. Hummmm now if I just had a reason to drill grain... Could make up something right??? :)
Thanks!
Andrew
12-30-2003 17:45:40
 Re: Looking for HP ratings in reply to Jeff, 12-24-2003 07:33:59
The Cockshutt 1950 105 PTO H.p, 1850 about 92 PTO H.p, 1750 80 PTO H.p, 1650 66 PTO H.p 1550 53 PTO H.p 1350 44 PTO H.p 1250 38.5 PTO H.p for that oliver 252 Disc id go with a 1750 if you had a need for speed but a 1650 would do to the 1750 had the wakashaw engine with a sleeve droping problem but if I can remeber you could fix that problem the 1650 was a great tractor we had one on our farm the last year when my grandfather died he left a crop of fall rye on we used the 1650 to run the 28 foot macdon swather going up a hill you could really work that 1650 (with a full swath) that year the crop varied from 45-75 bushals to the acre and the home quarter ran about 80-90 to the acre made the old 542 cockshut and the White 5542 work hard... id go with the 1750 or even the 1855 with the 354 Perkins...
evielboweviel
12-24-2003 17:40:20
how wide is the disk and how many blades?
E Je
12-24-2003 10:30:17
1550,53hp 1650,66hp 1750,80hp 1850,92hp 1950,gm 105 1950t,105hp. 1600,57hp 1800,73hp 1900gm,89hp 1555,56 1655,70hp 1755,86hp 1855,98hp 1955,108hp.
A.P.
12-24-2003 15:35:46
 Re: Re: Looking for HP ratings in reply to E Je, 12-24-2003 10:30:17
The 1900 horsepower listed is for the "A" model. The l;ater "B" and "C" versions carried a 100 hp rating. This is due to an incease in engine rpm and a four valve instead of the two valve head on the 4-53 Detroit Diesel engine used in all three models.
Merry X-mas
A.P.
old
12-24-2003 10:30:13
Try this site www.reunionofthepast.8m.net/Nebraska_Test
Jack
12-24-2003 08:00:14
Shoot Jeff if I had your wallet I would go to Iowa and get that 1855.You would look good operating that machine and that would yank the tongue out of your disc.Jack
Jack
12-24-2003 07:55:16
Throw some oil in the Supers hydraulics and come get her.It needs the legs stretched on it.
Jeff
12-24-2003 12:57:10
 Re: Re: Looking for HP ratings in reply to Jack, 12-24-2003 07:55:16
thanks for the info! I'll check that site as it sounds like a good one. I might take you up on that Jack but the cylinder has a small leak also and I am going to put new seals in first. You still wanting to drop the wieght of that old Super? This 88 I have has pressed steel on it, might be interested in trading if you want to.
Thanks everyone for the info and have a great Christmas!!!!
Jack
12-25-2003 06:34:40
 Re: Re: Re: Looking for HP ratings in reply to Jeff, 12-24-2003 12:57:10
Yes I am still interested.I really need to scale that joker and see what it weighs.I also need one of those roundtuit's cause I seemed to have lost mine.I hope them hubs will move on mine cause they will need to be all the way out.Jack
