water pump 90 Oliver
Martin Caldwell
12-20-2003 13:24:01
Can anyone tell me where I can get a rebuil kit for a water pump to fit oliver 90? Thanks for the help.
kline
12-21-2003 15:56:36
 Re: water pump 90 Oliver in reply to Martin Caldwell, 12-20-2003 13:24:01
R C Remanufacturing (724) 535-0338, he won't sell you any parts, but will rebuild it for you. did mine on my 99 works great.
RAB
12-21-2003 03:16:26
Hi Martin, Can't help with finding a rebuild kit but hope this helps if none is available. Mine has the carbon disc version of water pump. Made my own disc from an electrical brush and the new shaft seal was also from a box of electrical glands and seals, as I remember. The oilite bearings were purchased from a local bearing supplier and adjusted to fit. Made my own gaskets.
Has not leaked water in 15 years and throws oil all over the engine as normal, plus a bit - maybe my oilite bearings are too porous, or the previous wear on the shaft is a factor. So, which one do you have and how is it needing a rebuild?
Regards, RAB
