Jumping or Charging a 1650
Tim
12-18-2003 05:22:47
What is the correct way to charge the batteries on a 1650 diesel? I still have the two 6 volt batteries in this tractor. Un-hook them and charge them one at a time on 6 volt or can I hook the charger to one and set it on 12 volts?
ajax implement
12-18-2003 05:51:33
 Re: Jumping or Charging a 1650 in reply to Tim, 12-18-2003 05:22:47
Hook the positive lead of the battery charger on the same terminal on the starter as where the power cable comes from the batteries (top terminal). Put the negative terminal of the charger to a good ground. Set charger on 12 volts
Dean Barker
12-18-2003 16:02:49
 Re: Re: Jumping or Charging a 1650 in reply to ajax implement, 12-18-2003 05:51:33
This is the way I trickle charge my 1655 diesel; it has the two 6 volt batteries in series.
