cockshutt 40
art
12-17-2003 10:26:49
Need a overhaul kit and grill for a 1955 Cockshutt 40. Engine is a 6 cylinder Buda 260. Thanks, Art
P Heisey-Harleysville,PA
12-17-2003 16:17:59
 Re: cockshutt 40 in reply to art, 12-17-2003 10:26:49
Hi Art,
I have ''ALL'' the engine rebuild parts you will need plus many many more new and/or used Cockshutt parts.
If your 1955 Cockshutt 40 has the original gas engine, it is a Buda 6B230 engine. Email, call or fax for quotes.
Phil Heisey 215-256-8651 eve. FAX 215-256-1203
Irv
12-17-2003 14:48:32
Art, Int Cockshutt Club sells reproduction grills if this is what you want! As for rebuild kits for the 230 I have good luck with local reputable engine shops and NAPA there is also All Parts International in Fargo N.D. if you need other info email me and I will try to help. Irv in western Pa
art
12-17-2003 10:34:06
Maybe the engine is a 230 Buda. Art
J. Schwiebert
12-17-2003 15:51:44
 Re: Re: cockshutt 40 in reply to art, 12-17-2003 10:34:06
If it is the original engine it is a Buda 230. Remember Buda was purchased by A. C. and there are 262 engines. Give us a casting number off the block and we can verify this. I would guess it is a gas engine.
Jerry
12-17-2003 16:01:53
 Re: Re: Re: cockshutt 40 in reply to J. Schwiebert, 12-17-2003 15:51:44
If it has a spin on oil filter it might be a 262 Buda.
