best forum for white
ronohio
12-15-2003 17:16:53
Is Oliver the best place to read about and ask questions about White tractors or should it be the Misc Forum? Thanks.
Shep Va
12-16-2003 05:11:34
 Re: best forum for white in reply to ronohio, 12-15-2003 17:16:53
The earlier White tractors are a lot like the later Olivers, and there are several guys on here that have worked for White, so depending on what model White tractor you have, we can probably take a stab at it.
ronohio
12-17-2003 17:50:48
 Re: Re: best forum for white in reply to Shep Va, 12-16-2003 05:11:34
Shep, thanks for the comment. Working on a 2-105 right now. Had a skip and was going to pull it apart. Took it to the dealer instead, now $7000 later for an engine overhaul, I know I should have done it. He rebuilt it once but when we got it back had no oil pressure so he took it apart again and said it needed a new crank. Bought it at a neighbor's auction for $5000. He told me it was a good tractor? Had just sold his farm for a few million dollars so I thought he might be truthful. Now I have a $5000 with $12000 in it. So much for rich neighbors being truthful. Now I'm wondering if a 2-105 is any good as a tractor? The dealer put it on a dyno and got 135 HP he said.
Shep Va
12-18-2003 07:03:54
 Re: Re: Re: best forum for white in reply to ronohio, 12-17-2003 17:50:48
From what I know of the White 2-105 it is very much like an 1850 Oliver. The 354 Perkins engine is normally a very good engine with good power. It does have a closed center hydraulic system, and works very well with a loader.
Neighbor of mine has a 2-110 White, which is the same tractor only with a turbo, a full cab and a loader and it is the handiest tractor to feed with around. I really like it.
Sorry to hear you had trouble with yours. $5,000 is a really good price for a 2-105 White, I normally see them sell in the 8 to 10K range, and if you add a loader they can be more. So you probably do have more in it than its worth, but not by a lot. I think you will like the White once you get it going good.
Good luck
ronohio
12-22-2003 17:54:11
 Re: Re: Re: Re: best forum for white in reply to Shep Va, 12-18-2003 07:03:54
Shep, this 2-105 has a turbo on it. Do you think it has been added and isn't standard?
