Question about plows
Emery Courvelle
04-14-1998 12:29:18
Did Oliver make a row crop type plow from 1950 to 1953.
My dad has a set of row crop plows with adjustable
guage wheels and interchangeable plows. one set of plows was for making rows and the other for plowing up ground.
no name or numbers to be seen. can send pictures if
anyone has info. Thanks.
Larry H
04-14-1998 17:33:41
 Re: Question about plows in reply to Emery Courvelle, 04-14-1998 12:29:18
look on the back of the moldboards for numbers if there arent any ,check on the wheels we collect plows and maybe can tell you what you have also what kind of lifting system does it have : Did Oliver make a row crop type plow from 1950 to 1953.
: My dad has a set of row crop plows with adjustable
: guage wheels and interchangeable plows. one set of plows : was for making rows and the other for plowing up ground.
: no name or numbers to be seen. can send pictures if
: anyone has info. Thanks.
Emery
04-16-1998 10:39:56
 Re: Re: Question about plows in reply to Larry H , 04-14-1998 17:33:41
: look on the back of the moldboards for numbers if there arent any ,check on the wheels we collect plows and maybe can tell you what you have also what kind of lifting system does it have : : Did Oliver make a row crop type plow from 1950 to 1953.
: : My dad has a set of row crop plows with adjustable
: : guage wheels and interchangeable plows. one set of plows : : was for making rows and the other for plowing up ground.
: : no name or numbers to be seen. can send pictures if
: : anyone has info. Thanks.
Unable to find any numbers anywhere on the thing. They come rigged to mount to a tool bar. The guage wheels are metal with the wheel connecting back to the middle,
and the adjustment is coming out the top pointing forward. the length of the thing is approx 3 ft. the plow itself bolts to the back with a support going back toward the
middle. Very heavy duty. My dad bought them in 1953 for $250. He claims that he bought them from a "White" dealer. Thanks for your help.
