Why buy White?
Dexter
05-19-1999 19:52:34
I'm still reeling from the experience. I bought a White 2-85 last year that sounded fine, ran fine, and looked fine but the hydraulic oil kept getting very hot... even when not using the hydraulics. I posted a message on this site, got some good information about what the problem might be (thankyou) and took the tractor to a repair shop. Now, many dollars later, I am the proud (?!) owner of a tractor with a new hydraulic pump and a replaced GErotor assembly. I can live with a tractor that has a weakness that can be fixed but my question is what else can I expect? Does anyone know of other chronic weaknesses in this particular model that I should watch for? Are there any strengths? I could use a lift after having my wallet raped!
Al
05-20-1999 13:57:05
 Re: Why buy White? in reply to Dexter, 05-19-1999 19:52:34
That is one of the hazzards of buying off brand equipment.
mm
05-20-1999 16:44:09
 Re: Re: Why buy White? in reply to Al, 05-20-1999 13:57:05
You must be a JD man. Off brand isn't quite what most people think White is. The price may be conservative to the green or red or orange counterparts but the silver bullets have the same abilities. Many perfer the Whites to the NAME brand Green tractors. Its only natural to bitch when a off brand tractor breaks down. Hell, most buys with a JOHN DEERE won't tell when there tractor is in the shop.
dave
05-24-1999 17:35:10
 Re: Re: Re: Why buy White? in reply to mm, 05-20-1999 16:44:09
I agree with that. I am a White 2-85 owner. It is a heavier, and more solid machine than the comparable JD or IH. ANd with a great Perkins engine, and festooned with filters. That tells the story, when something is built to last, it has oil filters everywhere, and the hydraulic oil is separate from the trans with the wear particles, etc. Besides, WHite inherits the proud hart Parr and Oliver nameplates.
Adam
05-20-1999 13:51:53
Sounds like you had bad luck. What is a GErotor? It did solve the problem? I guess I am just courious what it is and or does. If I should ever run across such a problem. In the case of Oliver/White the tractors had a lot of features you can't find on the compitition like MFWD, usaly last just as long, are the nicest driving tractors around and are cheaper thats why I buy them.
mm
05-20-1999 16:47:50
 Re: Re: Why buy White? in reply to Adam , 05-20-1999 13:51:53
A gerotor is a oil pump that has an unusual volume for its physical size. It is a oil pump like ford has used for years on there automotive engines. One gear runs inside another gear. Minnie Mo started out with a hydraulic pump like this on the old U's years ago. Then when to a gear pump. Naturally, years and years later they go back to a gerotor. They are generally thought of as reliable.
C. Ziegler
05-19-1999 20:48:59
Dexter,
Please don't be discouraged by this purchase. Yes, the 2-85 and 2-105 suffered from hydraulic system problems. But now that this has been remedied, you should be able to expect years of reliable operation from this tractor. All the other systems on this tractor stand up to the White tradition of toughness and longevity that surpass the competition. Some may write in to talk about isolated incidents they may have had with this model, but the hydraulic system was the only real problem to affect so many 2-85s and 2-105s. The Perkins engines are well-built and the transmission lives up to the reputation Oliver earned for the best transmissions in the industry. You should be a very satisfied owner for years to come if you follow White's maintenance procedures as outlined in your manual. The best maintenance is preventative maintenance. Let me end by saying, and I think others will agree, congratulations on purchasing a White, the best name in the tractor industry with roots in the legendary Oliver Corporation. Again, please feel free to use this resource if you have any more questions about your 2-85. We're glad to help. P.S. If the system is no longer getting hot, then your relief valve must be set okay. This is many times the problem.
dave
05-24-1999 17:40:10
 Re: Re: Why buy White? in reply to C. Ziegler, 05-19-1999 20:48:59
To C Ziegler re your message:
A-Men brother!!!
I agree
Dexter
05-20-1999 20:42:09
Thankyou for the response. I am generally satisfied with the performance of the tractor but I do have a question about the transmission. There is a direct, over, and under type of "powershift" that I want to make sure I am using correctly. Should I be working in "direct" the majority of times and shifting "over" or "under" as the load on the tractor allows? I generally use the tractor for cutting and baling hay (9 foot haybine & a round baler). I know of problems arising from the incorrect use of the torque amplifier system in IH tractors, and people have told me about the powershift system in case tractors giving problems if they were underused (go figure!). What is the scoop with the 2-85?
Cory Ziegler
05-24-1999 08:22:57
 Re: Re: Re: Why buy White? in reply to Dexter, 05-20-1999 20:42:09
I agree with the two postings below. Use any range you wish at any time. All three are designed with equal strength to handle any job so don't worry when you've got a White.
Wrenchbender
05-22-1999 10:00:58
The over/under unit is very reliable. It sounds as if you are only doing light drawbar work,so any of the three speeds would be O.K. If you do any plowing or heavy pulling it is better to use under and direct,I use 3rd direct for plowing,4th direct disking and planting and shift down on the ends. Glad to hear you got your hyd. problem ironed out. I know Oliver/White parts are expensive,but so are parts for a Rolls-Royce! Good luck.
Pete in ks
05-21-1999 05:00:00
The over and under hydra power can be operated in any range at any time. Keep the filter changed as specified in operators manual and use the correct oil. Check level as you would the engine oil.
