Burned a valve
Nick
12-09-2003 08:43:17
The message below about sparks prompted me to write about our 1650 gas. We had replaced the head this spring because of a crack. We use this on a Knight vertical mixer to feed cows. Didn't use it this summer and put it on the mixer again this fall. It would kill after ten minutes of running. Start right up and go again and kill again. We put it on the dyno and loaded it pretty good but not quite full power. It ran good and then sounded funny. Shut the dyno off and the tractor had a burned valve just that quick. It was a new stellite valve with only 60 hours on it. We made sure the carb was clean and had very good fuel flow. We could not get it to flood out when you turned out the main fuel jet. We then bored out the econimizer jet .010" and now the carb can be adjusted properly. Instead of putting out 65 hp it runs an honest 80 hp. The moral of all this is the danger of running and engine too lean.
