Weight of an Oliver Super 88
Jim
12-08-2003 04:53:24
Can anyone out there tell me what the approximate weight of an Oliver Super 88 is? Also how much does each one of the standard rear wheel weghts weigh? Thanks!
turbo88 puller
12-08-2003 20:01:52
 Re: Weight of an Oliver Super 88 in reply to Jim , 12-08-2003 04:53:24
when i was running my 58 super 88 i had 18.4x38 rears on pressed rims 6 bolt rims on the front with no hyd no pto and no belt pulley, with weight brackets, wheelie bars and hitch i weighed 4150 without a driver
Nate
12-08-2003 09:29:10
My 1956 Super 88 diesel tipped the scales at 5450 when I took it to the pulls. Narrow front and loaded rears. I have cast centers on the rear with 13.6 x 38 tires. I didn't have any extra weights and she pulled terrific. First time pull got 3rd place. It was very well balanced when going down the track. The front end never came up and was just barely on the ground. That is where you want to be. It means all the weight transfered on your back tires.
Jack
12-08-2003 10:51:38
 Re: Re: Weight of an Oliver Super 88 in reply to Nate, 12-08-2003 09:29:10
Glad to hear that out of a Super 88.I am in the process of finishing my drawbar(20 inches high and 18 inches from the ctr of the rear axle)and ironing out the details on the wheelie bars.I was very interested in how much mine would weigh w/o fluid.I have cast centers front and rear with hydraulics.Later,Jack(TN).
A.P.
12-08-2003 05:26:51
A typical Super 88 will weigh between 5500 and 7000# (maybe +/- a little on each end of this span). Depending on whether the tires are loaded, wide or narrow front, etc. With pressed steel centers on the front and rear, no hydraulics or mechanical lift, belt pulley & drive removed, narrow front and a minimum of gas in the tank it should make it into the 4500# class for pulling. The rear wheel weights are 140# each.
Regards,
A.P.
