Repair of stripped tapped holes
mark miller
05-18-1999 19:42:17
I recently purchased a 1957 Oliver Super 55.
While mounting a back scoop I noticed that the lower connection pin for the three point hitch was loose. Upon further inspection I noticed that the previous owner had attemped to weld the pin to the axle housing. Unfortunately the pin is screwed into the main transmission housing and I believe the threads were stripped out of the housing. What is the best way to repair this? I am very concerned since this is obviously a high stress connection.
Pete in Post Falls
05-18-1999 21:20:04
 Re: repair of stripped tapped holes in reply to mark miller, 05-18-1999 19:42:17
I've had good luck with Heli-coils. Just about any Auto Parts place can show you. I like Napa. Its one of those things that's easier to see than tell.
Goto EMHART.COM and hit the white click here and follow trail to Heli-coils.
Good luck. Pete
Chad Wink
05-19-1999 11:15:30
 Re: Re: repair of stripped tapped holes in reply to Pete in Post Falls, 05-18-1999 21:20:04
Heli-Coils may work, but Caterpillar sells their version which works much much better in high stress areas. They may cost a little more, but they are really worth it.
