Oliver RC-60 ft oil seal source
GaryS - Texas
12-02-2003 13:33:56
Is there a source for the original style front crank oil seal that has a spring loaded cork ring?
I've ordered a re-designed replacement from Maibachs in Ohio that sounds complex and might require machining. Does anyone have experience, good or bad with the replacement?
Dennis(SoCal)
12-03-2003 15:05:30
 Re: Oliver RC-60 ft oil seal source in reply to GaryS - Texas, 12-02-2003 13:33:56
I recently replaced my front seal with a new cork front seal I purchased from Maibach. I did not soak it first and it leaked like crazy. I then put on a replacement seal from Korves that goes on the outside of the timing cover in place of the dust felt seal. This new seal, which costs about $6.75, stopped the leaking. I would recommend you don't bother with the old cork type seals, which are expensive, and just use the new neoprene seal that goes on the outside. Post again if you need help installing and I will give you a tip.
Dennis(SoCal)
12-03-2003 15:07:53
 Re: Re: Oliver RC-60 ft oil seal source in reply to Dennis(SoCal), 12-03-2003 15:05:30
Gary, sorry, but my replacement was on a 66, not a 60. Your's may be different.
