Super 88, no serial number tag
Randy Greni
12-01-2003 20:20:19
Just just got an ol fixer upper, A Super 88 Oliver.
There is no tag to be found for the serial number.
Is there anyway to find out by casting numbers, etc?? Thanks,
Randy
A.P.
12-02-2003 12:06:13
 Re: Super 88, no serial number tag in reply to Randy Greni, 12-01-2003 20:20:19
Take a rag and crawl under the rear end. There should be a date cast into the bottom. The tractor would have been assembled after that date (kind of hard to do before ;^) ).
Take care,
A.P.
Randy Greni
12-02-2003 09:07:57
The vertical number by the oil pressure line is, 971157.. One on the top rear side of the head (outside of valve cover) is, 2 4 55.. The casting number by the starter, 190320H and 1k100E. Also found Number on the flywheel, D190013A. Would the 2 4 55 on the head mean the year?
Also there is no tage to be found, on the panal or on the side of transmission
Thanks Guys!! I appreciate your efforts!!
Randy
J. Schwiebert
12-02-2003 13:32:07
 Re: Re: Super 88, no serial number tag in reply to Randy Greni, 12-02-2003 09:07:57
I do not have my little book right now but !K100E is a Super block. Also later Super's 1957 and up have key start and the battery cover on the hood is the full width of the hood and is held in place by four screws. Is this a gas or diesel? 1957 Models also have the word Oliver stamped in the fenders.
J. Schwiebert
12-02-2003 04:56:25
The Super series were built from the later part of 1954 through the start of 1958. First of all are you sure it is a super? Do you have a casting number for the engine block which will be behind the starter. Also the engine number is on the vertical flange in the right rear corner of the engine close to the oil line for the pressure gauge. did you look on the right side of the transmission case for a serial number tag in case it is a Fleetline 88 made before the fall of 1952?
If you take the hood off and the thermostat housing and maybe the valve cover a date is stamped in the head when that head was machined.
Gary
12-02-2003 05:32:10
 Re: Re: Super 88, no serial number tag in reply to J. Schwiebert, 12-02-2003 04:56:25
There is usually a date stamped also on the machined area where the fuel tank brk. is attached to the rear of the block.
