Cockshut 40 Govenor
kelly beech
12-01-2003 19:08:32
I was wondering if anyone knows anything about the govenors on the cockshut 40 tractors are they adjustable if so how the one I have either goes all the way down or opens all the way up it is not smooth just slow or fast could you help? Thanks Kelly
P Heisey-Harleysville,PA
12-02-2003 03:55:06
 Re: Cockshut 40 Govenor in reply to kelly beech, 12-01-2003 19:08:32
Kelly,
The overall length of the carb. to gov. arm rod must be 16 inches. Make sure the linkage is tight, but not binding and is well lubricated. Are the bearings good on the gov.shaft? Are the correct control springs and spacer in position at the governor?
If you provide your address, I will mail you more info. I have many of the replacement parts on inventory.
Phil Heisey 215-256-8651 eve. FAX 215-256-1203
