770 gas front oil seal leaking after changeout
gary
12-01-2003 14:28:38
when doing overhaul I changed out all seals the cork seals I soaked in oil for about 4 days.has a slight drip.cleaned the timing cover! any hints? will the seal need to wear for awhile? the rear seal seems to be doing ok.
rdh
12-03-2003 14:41:15
 Re: 770 gas front oil seal leaking after changeout in reply to gary, 12-01-2003 14:28:38
on my 77 I had a machine shop fit a automotive front timing cover seal in the front cover on tractor. stopped the leak which was almost a steady stream with a new cork seal.
Gary
12-02-2003 05:37:24
Did you check the thrust brg. clearances close? I've seen these wore enough which will let the crank move back and forth enough to pull the seal away from the cover.
RWT
12-01-2003 20:56:26
I was just thinking. I believe most of these tractors have aluminum front covers. If there was a groove wore in the cover were the seal ran I don't think it will seal. It would take replacement or repair.
RT
WFE
12-01-2003 20:46:20
These can be tricky. Eventually they will 'wear' themselves in, but likely the sealing face on the front timing cover has some minute grooves worn in from the previous seal. The new seal will eventually wear in to seal this, or, the front timing cover sealing face can be lightly sanded or polished smooth when replacing the seal.
