a few more 550 block heater questions
matt
11-30-2003 17:48:40
Hi all,
I had posted a few weeks ago about a block heater for my 550 and i finally got one in from the tractor supply place near me. It is a Kat in-line heater 1 1/2". I thought i knew where i was going to put it, but when i opened it it said not to put it in rad hose that has metal wire in it. So then i was looking at the metal hose that is attached to the bottem of the radiator and was wondering if i should cut out a section of that and splice it in there. The only problem is that in order to splice it in there i will have to use some kind of rad hose....Is there something special out there that i should use or is it not that big a deal to use the regular hose? If not why not?
thanks for the help
matt
RockinB
12-01-2003 02:56:00
 Re: a few more 550 block heater questions in reply to matt, 11-30-2003 17:48:40
Just put one in my 550.Used the Original equip. cast iron elbow,85 dollars at AGCO dealer.It is drilled &tapped on the bottom for Kat heater,another 29 dollars.Works great,well worth the money.Sure improved the cold starts.The old one with a cut off cord was a cobbled in the hose affair,have no idea how it ever worked.The cobbler used 2 inch radiator hose and many many clamps to adapt to 1 1/2 inch outlets.
matt
12-01-2003 06:09:39
 Re: Re: a few more 550 block heater questions in reply to RockinB, 12-01-2003 02:56:00
Just wondering what the heater looked like. My oliver has a lower metal rad hose that has what looks like a 5/8" bolt(just from memory) on it toward the bottom. Could this be what you are talking about with the original cast iron elbow? If so can you describe the Kat heater and/or give me the part number?
thanks so much
matt
RockinB
12-01-2003 07:42:45
 Re: Re: Re: a few more 550 block heater questions in reply to matt, 12-01-2003 06:09:39
The new original equip. part is hard to describe.It's about 8" top to bottom with a 3/4" pipe thread at bottom to receive heater, about three quarters of the way down from the top of this straight piece an albow comes off of it that is connected to the bottom radiator hose connection with approx. a 4 1/2 inch radiator hose. The top of the straight part connects to the water pump with about a 2 inch radiator hose. E-mail me and I will send photos and part number of Kat heater.
old
11-30-2003 18:04:03
You can use plain jane rad. hose heater olny warm the engine to around 70 to 100 degrees which is less then what the hoses have to work with when the tractor is running
matt
12-01-2003 06:05:28
 Re: Re: a few more 550 block heater questions in reply to old, 11-30-2003 18:04:03
Can you give me a few more details on what you mean by a plain rad hose heater. I thought that was what i had. Mine is an in-line heater that i have to splice in. Many thanks
matt
