Oliver 2150 PTO
olg1355
11-26-2003 05:00:44
Where is this pan that you guys keep talking about? I just bought one and want to make sure it is out. I have a parts book if it is in there give me the part number and I will find it.
Brad
11-26-2003 14:25:51
 Re: Oliver 2150 PTO in reply to olg1355, 11-26-2003 05:00:44
I don't have the number in front of me, but you have to remove the hydraulic unit to get rid of it. It is underneath the hydraulic idler gear, and is about 3 inches wide and 8 inches long. I would reccomend replacing the idler bearings at the same time.
Ed
11-29-2003 15:17:35
 Re: Re: Oliver 2150 PTO in reply to Brad, 11-26-2003 14:25:51
What is purpose of this pan in 2150 tractor? Why would you want to remove it?
Brad
12-04-2003 19:54:29
 Re: Re: Re: Oliver 2150 PTO in reply to Ed, 11-29-2003 15:17:35
The purpose was to keep oil from getting on the pto shaft and working it's way up to the clutch. It did it's job too well, it also kept oil from lubricating the hyd pump drive bearings and they have been known to go out and destroy the gears and the rear end housing
Johnnie T
11-26-2003 17:00:45
Do 2050 have the same pan
Brad
11-27-2003 12:41:17
 Re: Re: Re: Oliver 2150 PTO in reply to Johnnie T, 11-26-2003 17:00:45
Yes, they do.
