Interchangeability Between 77 And 88 Parts
Ross Boots
11-25-2003 20:26:25
Will the camshaft or pushrods out of an Oliver 77 work in a Super 88 engine? Thanks in advance for any replies.
Brad
11-25-2003 21:22:03
 Re: Interchangeability Between 77 And 88 Parts in reply to Ross Boots, 11-25-2003 20:26:25
The camshaft is different, pretty sure the pushrods are the same.
old
11-25-2003 20:42:44
The catalog I have says they are not the same parts number so I would say no. You could go to olivertractor.com and ask Larry and or you can send me an e-mail and I'll give you the phone number for the place that has the parts you need.
Poor Larry
11-25-2003 21:38:08
 Re: Re: Interchangeability Between 77 And 88 Parts in reply to old, 11-25-2003 20:42:44
Why don't you go back to the saying "buy a manual" ,and give Larry a rest.
old
11-26-2003 08:29:33
 Re: Re: Re: Interchangeability Between 77 And 88 P in reply to Poor Larry, 11-25-2003 21:38:08
Because a manual will not answer a question like that. And the reason Larry has his web site is to give people info, Not for smart A$$ like you
Think he will get the mes
11-26-2003 06:31:36
Think he will get the message? Maybe he should check with Larry.
J. Schwiebert
11-26-2003 04:05:32
I am not so sure, going on memory but when the super's were introduced the rocker arm supports changed and so did the push rods. Guess the best way is to measure the length. They will look different.
dan
11-26-2003 20:30:59
 Re: Re: Re: Re: Interchangeability Between 77 And in reply to J. Schwiebert, 11-26-2003 04:05:32
not sure on the push rods. the cams are definately not. there is 15/16 of an inch difference in length.
