Price check super 55
Larry
01-12-1998 21:59:07
I ran across an ad for a Super 55 with 3 point. Ad says it runs great but I have not seen it personally. Asking price is $3500.00. That seems a bit high to me but I thought I would go to you good folks on the Oliver board and see what you think. Any strong feelings?
Bob Skurka
01-13-1998 05:49:27
 Re: Price check super 55 in reply to Larry, 01-12-1998 21:59:07
: I ran across an ad for a Super 55 with 3 point. Ad says it runs great but I have not seen it personally. Asking price is $3500.00. That seems a bit high to me but I thought I would go to you good folks on the Oliver board and see what you think. Any strong feelings?
I paid $2650 for a 1955 Super 55 Diesel. The grill was missing, the tin was dented, the lights gone, the guages broken and the exhaust was re-routed to run under the axel so it could start grass fires. BUT THE ENGINE RUNS STRONG AND THE 3PT AND THE HYDRAULICS ALL WORK WELL.
From what I have seen, the Super 55 is a little more expensive than the common, and less capable & less powerful Ford N's and NAA's. Given what I have in parts alone, you are getting a deal at $3500 if MOST of the tractor is there and it runs. I paid $330 for a grill alone. I can't find lights at all. Guages cost me another $125 for Oliver reproduction guages. I figure by the time I paint this tractor I'll be pushing $4500, but it will be restored to near original condition and will be a good working tractor. At $4500, I figure it will save me about $15,000 compared to buying a new Kubota or other lightweight import.
Bob Skurka
01-13-1998 09:32:38
 Re: Re: Price check super 55 in reply to Bob Skurka, 01-13-1998 05:49:27
: : I ran across an ad for a Super 55 with 3 point. Ad says it runs great but I have not seen it personally. Asking price is $3500.00. That seems a bit high to me but I thought I would go to you good folks on the Oliver board and see what you think. Any strong feelings?
: I paid $2650 for a 1955 Super 55 Diesel. The grill was missing, the tin was dented, the lights gone, the guages broken and the exhaust was re-routed to run under the axel so it could start grass fires. BUT THE ENGINE RUNS STRONG AND THE 3PT AND THE HYDRAULICS ALL WORK WELL.
: From what I have seen, the Super 55 is a little more expensive than the common, and less capable & less powerful Ford N's and NAA's. Given what I have in parts alone, you are getting a deal at $3500 if MOST of the tractor is there and it runs. I paid $330 for a grill alone. I can't find lights at all. Guages cost me another $125 for Oliver reproduction guages. I figure by the time I paint this tractor I'll be pushing $4500, but it will be restored to near original condition and will be a good working tractor. At $4500, I figure it will save me about $15,000 compared to buying a new Kubota or other lightweight import.
Larry,
Per your direct email to me about the 550 vs. Super 55 comparision:
My understanding of the 550 is it is virtually identical to the Super 55
with some cosmetic (sheet metal) and minor mechanical changes. I
regually email to/from a 550 owner, and from what I gather, he has the
same tractor as my Super 55. I think the 550 may have a couple more
horsepower, literally only 2 or 3 more hp. Obviously the sheet metal is
totally different and updated. But my understanding is the 550 and the
Super 55 are the same tractors.
I bought my Super 55 to care for about 5 rough acres, to help build a
small orchard (couple dozen trees), tend a large (1 acre) garden and to
landscape around the property. I have only played with the tractor at
this point, and currently it is in pieces in my neighbor's shop while we
restore it...to be put to real use this spring. I can see no reaason
why it shouldn't do everything I need. It is very stoutly built, more
so than the common Fords, it has lots of power, and it is small enough
to used on my size property.
Bob
Tom Timmons
01-13-1998 02:32:24
Larry,
Local John Deere Dealer here also has a Super55
set up with 3 pt. and so on. Asking price is the
same. The one here (Central Michigan) was a real
mess when it came in. They tuned it up, put on a
new exhaust system and a battery. It has a repaired
motor mount on the right front, where the block has been welded....
Seems to be in line with the prices here.
Tom in Frankenmuth
