adding hydraulic ports on 770/880
Chip
11-23-2003 18:21:13
I want to run a log splitter off of either my 770 or 880. I could run the cylinder off of the hydraulics, but I want to have the valve body down by the splitter. The book shows where to hook up the supply and return, but what I want to know is can I just put couplers at those points and plug in the splitter when I want? Or do I have to keep that as a circuit all of the time? If I just put couplers on will it dead head and granade the pump if nothing is hooked up? Thanks guys. Chip
Scott Green
11-24-2003 02:28:31
 Re: adding hydraulic ports on 770/880 in reply to Chip, 11-23-2003 18:21:13
Chip , the pump runs all the time , wether you use it or not.
oleblu
11-23-2003 19:15:20
Chip, I'm not sure if your pump will shoot craps or not, but I doubt it. An alternative would be to plumb up your hoses to the back of the tractor like you want, THEN put your valve (open center, of course) on the hoses, THEN add your QD couplers to the valve. Circuit is freeflowing, no pump problems, valve is located on the rear so it's easily accessable, and you have the couplers so you can take the splitter off. oleblu
