Looking for RB
Larry
11-23-2003 15:01:07
RB, I was reading the past post on Crowley fans and I was interested in a 6 or 8 bladed fan for my 1855. I was inquiring if you had gotten a 6 or 8 bladed fan, and if you had, would you post the part numbers from Crowley on 6 or 8 bladed fans for 1855 or 1955's. I'm sure there are others interested in the fans. Thanks for all the information.
Thanks Larry
RB
11-27-2003 17:42:58
 Re: Looking for RB in reply to Larry, 11-23-2003 15:01:07
Three things are needed.
1.The size of the fan hub hole in the current Waukesha/Oliver fan. (I haven't determined this yet.)
2. The overall fan diameter. (It is 20 inches.)
3. Drive ratio of diameter of the fan pully to the crankshaft pully. (This is 1:1.2.)
Multiply this ratio by the engine full no-load speed to get airflow. (Using 2500rpm, you get fan speed of 3000rpm. Using 2600rpm, you get 3120 rpm.) More info will follow when found.
RB
11-23-2003 18:08:18
I got some info from the Crawley company, but I haven't got all my stuff togather to order the fan. I guess I have procrastinated. I will look for my written material about this, and get back to you on it. Thanks for reminding me about it.
