oliver engine?
slowsmoke
11-23-2003 09:09:39
Can anyone tell me what engine this is? it's an Oliver 6 cyl diesel, had roosa master on it. block #'s are 155720A-221120
many thanks
B A Star
11-23-2003 21:46:15
 Re: oliver engine? in reply to slowsmoke, 11-23-2003 09:09:39
The crankcase with # 155 720-A cast into it was used on the 1800 "B" series tractors. Tractor serial numbers for "B" series is #124 396 - 134 685. Same crankcase used for gasoline & diesel.
slowsmoke
11-24-2003 03:48:22
 Re: Re: oliver engine? in reply to B A Star, 11-23-2003 21:46:15
Thanks. Are there any numbers on the head? what is this used head worth? It's complete, the block scttered pretty hard(#4 went BOOM)
slowsmoke
11-24-2003 04:53:35
 Re: Re: Re: oliver engine? in reply to slowsmoke, 11-24-2003 03:48:22
#'s on head: "C"(or G) 221"8" 02"B' What Thanks again. Don
J. Schwiebert
11-24-2003 11:41:25
 Re: Re: Re: Re: oliver engine? in reply to slowsmoke, 11-24-2003 04:53:35
There will also be an Oliver part number stamped with a number set and a date, month & year close to thermostat housing.
J. Schwiebert
11-23-2003 14:35:00
It is a 7 main bearing engine, I am trying to remember but it kind of sounds like an 1800 B or C. What does the oil filter look like? I am trying to remember what the casting numbers were on the early 1650 diesels.
Brad
11-23-2003 20:17:26
 Re: Re: oliver engine? in reply to J. Schwiebert, 11-23-2003 14:35:00
Sounds like a 7 main crossfire. don't remember model/casting numbers for sure, but sounds like 1800. get the serial number off block, there was some water port changes on the 1800's that could cause cooling problems if the wrong head is installed. number is on right front corner of block, I think it is 6 digits.
P.S. all the 221 blocks are 7 main.
Me
11-23-2003 14:53:37
Can't even spell "head" don
slowsmoke
11-23-2003 14:52:43
oil filter is a vertical canister. pump is "DBGFC631-1DW" Moter is scattered, just wondering what the haed will fit. Thanks, Don
J. Schwiebert
11-23-2003 14:39:26
I forgot to include this. To you have an exact model for the Roosa pump DBGFC ????
