550 Power Steering
Gaston Tew
11-20-2003 09:59:49
Did Oliver ever make the 550 power steering without external cylinders. Went to look at one and the fellow said the later models had all controls in the steering column, however you can see it at one time had the external cylinders.
jake
11-21-2003 09:05:40
 Re: 550 Power Steering in reply to Gaston Tew, 11-20-2003 09:59:49
If it had cylinders in the past the control on the steering box was removed and replaced with a standard steering shaft. The early 55's had a torque amplifier powered by an auto type oil pump at the rear of the generator. Examples of this can be found at www.jacksonpowersteering.com. The Fords [8N up] have the same type [saginaw recirculating ball] as used on Olivers
Brad
11-20-2003 22:22:36
The early 550's had a char-lynn torque motor on top of the steering box that did not use external cylinders. all the late ones that I have seen had external cylinders.
Mike (WA)
11-21-2003 08:24:46
 Re: Re: 550 Power Steering in reply to Brad, 11-20-2003 22:22:36
The unit on base of steering column will have only two tapped holes for hydraulic lines if its the Char-Lynn (non external cylinder) model- but will have 6 tapped holes if external cylinder type.
