550 Gas Question
Allen Lancaster
11-20-2003 06:33:10
I recently purchased a 550 Gas with a loader. I can tell now that I have much to do to get it in shape. among many needs is brakes. I have not tried to adjust them yet but I am about certain it needs lining. Where would I be able to find brake linings and is it a hard job to do? Thanks again for your time and help. Regards, Allen
Kenny
11-20-2003 15:47:30
 Re: 550 Gas Question in reply to Allen Lancaster, 11-20-2003 06:33:10
Allen
I'm also in the process of rebuilding a 550 gas that had a loader on it. One of my biggest problems was it had set for several years. I have replaced every seal in the trans. & hydraulics. i'm in the process of replacing the front end pivot pin. the previous owner forgot that it had grease fitting.
I found it was easier for me to take steps off so I could get to brake adjusters & made more room to pull brake housing off & get them back on. If you need help just let me know.
Allen
11-21-2003 10:23:38
 Re: Re: 550 Gas Question in reply to Kenny, 11-20-2003 15:47:30
Thanks to all of you! Kenny-I think you and I are in the same boat or rather similar Olivers. Your suggestion in taking the step loose to adjust or replace seems like the answer. I will do this. do you have an E mail that I could contact you at times. I have so much to do to this tractor. Regards, Allen
Kenny
11-21-2003 16:05:39
 Re: Re: Re: 550 Gas Question in reply to Allen, 11-21-2003 10:23:38
Allen
Yes & you can E-mail me any time.
I have a shop manual that helps on some of the stuff.
The rest you have to use alittle brain power.
ShepFL
11-20-2003 09:39:57
I got mine from Val-u-Bilt. Requires 4 plates.
