oliver 77 (puller)
Ryan Eslick
11-19-2003 08:48:31
I am looking to build a oliver 77 into a tractor puller over the winter and i have no idea where to start. i have built 2 allis wc's into strong running pullers but never an oliver. If any one could give me some ideas on what to do to the engine that would help me out a lot.
thanks Ryan
Brad
11-19-2003 15:22:41
 Re: oliver 77 (puller) in reply to Ryan Eslick, 11-19-2003 08:48:31
What are the classes you want to run in? what weight, speed limit, or any other rules?
Ryan Eslick
11-19-2003 17:02:52
 Re: Re: oliver 77 (puller) in reply to Brad, 11-19-2003 15:22:41
The classes I'm wanting to pull in are the 4000, 4500, and possibly the 5000 open classes. Speed limit is unlimited. I have to use original 77 block, that is about it on rules on engine. Thanks
Ryan
Brad
11-19-2003 21:47:07
 Re: Re: Re: oliver 77 (puller) in reply to Ryan Eslick, 11-19-2003 17:02:52
Well now, those are the kind of rules I enjoy working with the most. I would suggest going with big bore, but keeping the stroke mild. you can bore the block out and use aftermarket 88 sleeves. they had a bigger outside diameter and you can bore them out to 4 1/16 bore. this allows use of most smallblock .060 over automotive pistons and there is almost any piston you may need on the shelf. I fill the block on almost any engine I build. it makes everything more solid and helps prevent the sleeves from distorting mostly during the power stroke. You can take one of the freeze plugs out of the back of the head and use a electric pump to cool the head. a copper head gasket transfers most of the heat from the block to the head and keeps it reasonably cool. as far as stroke and rods, I'm not too fond of welding the crank up on a unlimited rpm motor, you could offset grind the super 77, 770 and 1550 crank to a 2 inch journal and end up with a 4 inch stroke. the prefect rod length for that engine is 7 inch. I have looked hard and not found a 7 inch rod with a 2 inch journal. the closest I have found is a 188 diesel case engine. they had a 2 1/16 journal. but these rods are almost too heavy for what you're doing. I havent seen a 188 gas rod, but they may be a good option, welding the crank a little is not too bad. with some big valves, good headwork, a cut down 1650 intake manifold, and a good camshaft you would have a real strong 311 cube 4500-5000 rpm engine.
Ryan Eslick
11-20-2003 09:22:43
 Re: Re: Re: Re: oliver 77 (puller) in reply to Brad, 11-19-2003 21:47:07
I guess one rule i forgot to tell u is that on the rpm's is in the open class we can only go 20% over stock rpm's.
Brad
11-20-2003 22:31:47
 Re: Re: Re: Re: Re: oliver 77 (puller) in reply to Ryan Eslick, 11-20-2003 09:22:43
that changes things a bit. A limited rpm no speed limit class usually takes a pretty serious engine to be tough. If it was me, I would start with a 88. If that is not a option, everything I said still applies except for the stroke. you can run up to 5 1/4 stroke with a c123 farmall rod and alot of grinding on the block and camshaft. This would make 408 cubes. though you could build a 88 the same cubic inch for about the same money and have alot more power.
Ryan Eslick
11-21-2003 10:34:12
 Re: Re: Re: Re: Re: Re: oliver 77 (puller) in reply to Brad , 11-20-2003 22:31:47
What your telling me sounds like a good idea to me and I was just wondering if I coudl get your phone number so I could talk to you in person a little more in depth about this. Thanks, Ryan
Brad
11-21-2003 18:11:59
 Re: Re: Re: Re: Re: Re: Re: oliver 77 (puller) in reply to Ryan Eslick, 11-21-2003 10:34:12
330-939-0124 I probably won't be around the phone, leave a message i'll call you back as soon as I can.
dan
11-22-2003 18:45:13
 Re: Re: Re: Re: Re: Re: Re: Re: oliver 77 (puller) in reply to Brad, 11-21-2003 18:11:59
i have built a 77 to 476 inches,it gets tight,takes alot of custom machined parts. the only reason to use a 77 instead of an 88 was to get in the 3500 lb. the 88 was 524 inches done the same way.
