type oil
bill
11-18-2003 12:52:31
i got a 1650 diesel and it doesn't start after being used. It will after it cools down. also at startup the pressure is about 40. after warmup it drops to 10-15psi. is this normal or did the previous owner put the wrong oil in it. if so what type of oil should i run in it.
Brad
11-18-2003 14:59:54
 Re: type oil in reply to bill, 11-18-2003 12:52:31
The starting problem is most likely due to a worn out injection pump. When they get worn and everything gets hot, the clearences get too big and the fuel bypasses into the return instead of going to the injectors. most likely the oil pressure is either going to be lived with or a major overhaul will have to be done. it is most likely due to excessive bearing clearence and rolling a set of bearings into one of those engines is not a option, they usually end up in the oil filter in tiny pieces. A real good used or new oil pump would'nt be a bad idea though. also the first thing to do would be install a new bypass plunger and spring in the right front corner of the block.
Jerry B
11-19-2003 05:28:55
 Re: Re: type oil in reply to Brad, 11-18-2003 14:59:54
Why is it not an option to roll a set of inserts into these engines? What do you mean "they end up in the oil filter in tiny pieces"? The new bearings or the old bearings?
Brad
11-19-2003 15:18:45
 Re: Re: Re: type oil in reply to Jerry B, 11-19-2003 05:28:55
The blocks in these tractor did not have any more cast iron in them than they needed to. when you put a engine together with a reground crankshaft and a good linebore and new bearings, everything flexes around a little and over time they wear in. when you put a new set of bearings in the worn crankshaft journals are not perfect and usually it chews up the bearings and they end up in the oil filter. It seems like this normally happens about 100 hours later. Of course, there are always a few exceptions, but by far this is what happens with the majority of them.
