Oliver 1800 gas no spark
DAVE
11-17-2003 18:52:58
I have a 1960 Oliver 1800 A series with the 265 gas in it. Tractor ran well prior to redoing alot of things to it over the past year. I am now ready to start it back up and now I have no spark. I have rewired, new coil, points and condenser, wires, plugs, etc. All of it. Wiring by the book. I am lost as I cannot find the cause. Suggestions apprecaited. I am stuck!!
Don-Wi
11-18-2003 20:16:02
 Re: Oliver 1800 gas no spark in reply to DAVE, 11-17-2003 18:52:58
Just had simialr problem on our 165 after the points burnt up. Turned out the + wire from the coil to the condenser/ points under the cap was grounded to the distributor. Only thing I never looked at. Donovan from Wisconsin
DAVE
11-19-2003 11:51:54
 Re: Re: Oliver 1800 gas no spark in reply to Don-Wi, 11-18-2003 20:16:02
Don,
I have been looking for a short. Has to be something small like that. I will check. I have missed a step somewhere. I have never had this trouble before. NASCAR would have fired me by now on this one.
oleblu
11-17-2003 19:17:44
Dave, have you checked the key switch? Had to replace mine, it just failed to work. oleblu
DAVE
11-18-2003 13:09:02
 Re: Re: Oliver 1800 gas no spark in reply to oleblu, 11-17-2003 19:17:44
Old,
The tractor turns over well and I have fire on the solinoid. What should I look for on the switch. I have 4 terminals, ACC, SOL, IGN, and I can't remember the other one out of my head. Should there be something I should check for. What was wrong with yours?
oleblu
11-18-2003 17:23:00
 Re: Re: Re: Oliver 1800 gas no spark in reply to DAVE, 11-18-2003 13:09:02
Dave, mine would crank just fine but no juice to the coil. We ran a jumper wire from the battery to the coil and it fired right up. I think the switch was a little over $20 from AGCO.oleblu
Dave
11-18-2003 18:53:17
 Re: Re: Re: Re: Oliver 1800 gas no spark in reply to oleblu, 11-18-2003 17:23:00
Old,
I will take a look. The switch is new but you never know. I had 12 volts to the coil on the meter. I am wondering if the new points or shorting out or the new condenser or new coil is trouble. I have done something stupid but I have never come across this before. I will give it a try and see how it does. Thank you for the idea.
RockinB
11-18-2003 19:05:10
 Re: Re: Re: Re: Re: Oliver 1800 gas no spark in reply to Dave, 11-18-2003 18:53:17
Try roughing up the surface of the condenser with some coarse emery paper, especially if it's a Mallory with the gold colored coating.
DAVE
11-19-2003 11:53:46
 Re: Re: Re: Re: Re: Re: Oliver 1800 gas no spark in reply to RockinB, 11-18-2003 19:05:10
RockinB,
Roughing up the surface for contact. Never thought of that. I will examine. Thank you for the imput.
RockinB
11-19-2003 15:14:00
 Re: Re: Re: Re: Re: Re: Re: Oliver 1800 gas no spa in reply to DAVE, 11-19-2003 11:53:46
Yes better contact with the clamp. Got this from a Mallory factory rep after having similar trouble with my 1550 last spring. I'd had the Mallory in it for about five years and after replacing points & cond. it would not fire. Drove me nuts trying to figure it out.
J. Schwiebert
11-18-2003 16:42:49
With the old switch, if you turned switch on and if unhooked the wire from the switch to the coil and checked it with a light or voltmeter did you have power? If not, do you power to the switch. If you do switch is bad. If I remember correctly the other terminal is the Battery terminal in other words the power source.
Dave
11-18-2003 19:00:00
 Re: Re: Re: Re: Oliver 1800 gas no spark in reply to J. Schwiebert, 11-18-2003 16:42:49
John,
I have all new everything. The old stuff was a mess but it did run. I have 12 volts to the coil according to the meter. The motor turns over strong. I made a new harness. I do this everytime so I know what I have. I could have a set of new points that are shorting out, bad new condenser, new coil bad? This thing has got my goat. I have probably done something stupid but I can't locate that either. I will check the switch like you said. I appreciate the insight. I have none now.
