RC-60 engine oil leak at pulley
GaryS - Texas
11-17-2003 12:03:28
An oil leak at the front of the engine appears to be coming from the outside rim of what appears to be a cup that is press fit into the block aroung the end of the crankshaft. The book diagram is very poor. Do I have this remotely right? If so what seals the outer rim of this cup against the block - the current sealing material appears to be soft. Does the crank seal fit inside this cup?
Any guidance would be appreciated.
Larry
11-18-2003 09:44:58
 Re: RC-60 engine oil leak at pulley in reply to GaryS - Texas, 11-17-2003 12:03:28
Sounds like a front main seal, they can be replaced with the engine in frame, I think, but much easier if it's out of frame. If the leak isn't too bad, try some stopleak additive.
Larry
