880 clunking sound
Jeff
11-16-2003 21:01:35
Hi, I have an Oliver 880 RowCrop that makes a clunking sound. It is loudest when in 5th and 6th gears. It is like a loud knocking. The bearings on the transmission shafts are good as I just checked them. I haven't pinpointed the location of the sound. Anyone have the same problem on their tractor or know what the cause of the problem may be? Any help is appreciated. Thanks, Jeff.
Rich
11-17-2003 18:39:36
 Re: 880 clunking sound in reply to Jeff, 11-16-2003 21:01:35
I suggest checking the hub U bolts, they may feel tight, but many times they have worked loose and allow the hub to shift on the axle. If the noise is coming from under your feet, I would suspect a cracked bull gear.
Scott Green
11-17-2003 05:25:41
One thing you can try ruling out; Check and see if the lugs , which hold the rear rim to the cast iron wheel , are tight. I once had an Oliver "70" with the same noise you describe. Every time the wheel went around , I herd a clunk. It ended up being the rim , shifting on the wheel.
Larry from MD
11-17-2003 09:33:21
 Re: Re: 880 clunking sound in reply to Scott Green, 11-17-2003 05:25:41
Allso check any rear wheel wieghts.
Canada Grant
11-18-2003 16:11:06
 Re: Re: Re: 880 clunking sound in reply to Larry from MD, 11-17-2003 09:33:21
Front bearing on pinion shaft went on my 880 clunked going down hill no load . Replaced bearing [big job] and rear end never sounded this good in 10 plus years! You can check from outside at front of trany below input shaft.
