hydrolic oil
matt
11-16-2003 07:46:38
Hi guys, I feel really silly, but i just bought an oliver 550 and was changing the fluids the other day. I was reading the manual and it said that i should fill the hydrolics with 10w 30 oil... i noticed that it was very different from what came out, but i figured that if the book said that it was ok then thats what i should do. then i was at the store i saw hydrolic fluid on the shelf. Do i need to drain the other oil out and put in the right stuff or is this ok for awhile? Am i screwing something up?
thanks
matt
Larry from MD
11-16-2003 08:32:38
 Re: hydrolic oil in reply to matt, 11-16-2003 07:46:38
Yes drain out the 10w 30 moter oil it is a deturgent oil.Years ago when the books where written moter oil was non detegent and could be used in hydrolic systems,but NOT now.
J. Schwiebert
11-17-2003 06:54:17
 Re: Re: hydrolic oil in reply to Larry from MD, 11-16-2003 08:32:38
Larry, Larry. I agree that years ago they said no detergent oil in hydraulic systems. That has changed. There are some advantages to using a multiweight detergent oil. The advantages are because of the additives. When I did some old Tyrone (hydraulic pumps) hydraulic product classes they even had a bulletin listing the advantages of using a detergent motor oil
matt
11-16-2003 10:40:02
do i need to flush it out somehow? have i done any damage?
Kenny
11-16-2003 14:42:48
 Re: Re: Re: hydrolic oil in reply to matt, 11-16-2003 10:40:02
Take Hose From your remote Cyd. location with snap coupler on it or take one off cylinder.
The book says start tractor at idle and operate remote lever. This the best to drain the Hyd. oil.
