Oliver 80 Row Crop
Dominic Centonz
11-16-2003 07:41:43
Hello Oliver friends. I found an Oliver 80 row crop with a very good and clear serial tag: ser# 104518. The tractor has a wide front. It is crank start. Problem is, it is in really rough shape. It is stuck bad, with one rear rim rotted away, manifold busted. Carb and Mag are there. I want to make an offer to the person who has it. Is it an uncommon tractor? And what year is it? Any help from anyone would most sincerely be appreciated!
UK Row Crop
11-16-2003 12:07:18
 Re: Oliver 80 Row Crop in reply to Dominic Centonze, 11-16-2003 07:41:43
An 18-27 will say hart-parr on radiator and engine block.
Going by serial # it's an 18-27.
J. Schwiebert
11-16-2003 09:08:01
104 518 would be an 18-27 or what is known as a Standard Rowcrop. Check and see if the numbers 18-27 do appear on the serial number tag.
Larry
11-16-2003 08:04:50
My book says that they started in 1937 at serial # 109152. So if you mixed the 9 for a 4 yours would be a 1937. Hope this helps. Larry
len
11-16-2003 12:25:38
 Re: Re: Oliver 80 Row Crop in reply to Larry, 11-16-2003 08:04:50
I'm restoreing an 80 rc , hard to find parts for might be able to help find some parts, they ar'nt worth a lot as is. restored about 2500-3000.I have seen very few around at shows. len
