how to one wire a 1750?
big M
11-11-2003 21:48:17
I searched the archives but couldn't find a post on how to one wire my 1750 diesel. Can someone run me through the process? Also, my lights are disconnected. What do I hook them up to?Thanks
Myron KY
11-13-2003 11:10:23
 Re: how to one wire a 1750? in reply to big M , 11-11-2003 21:48:17
Big M, On the original alternator there was a dark green wire connected to it's "B" or "BAT" terminal. This green wire runs directly to the Amp gauge. Connect your one wire to this dark green wire. You can also connect the one wire directly to the battery, but the Amp gauge will show discharge all the time. The one wire alternator has a self exciting voltage regulator. You'll need to rev the engine up to make the alternator start charging. The alternator has to be spinning approx. 1600 to 2000 rpm before the regulator excites. Once excited it will continue to charge even at lower RPMs. I'm not sure what RPM the engine has to be to equal 2000 RPM on the alternator. Some install a smaller diameter pulley on the alternator so fewer engine RPMs are needed to excite.
Are your lights disconnected it the dash or somewhere beyond that point? You may want to get a wiring diagram. The Oliver and I&T service manuals, for your tractor, have the diagrams.
Hope this helps
Myron KY
Big M
11-13-2003 21:14:16
 Re: Re: how to one wire a 1750? in reply to Myron KY, 11-13-2003 11:10:23
Thanks, Myron. So the green wire becomes my one wire? And do I pull off the voltage regulator and all the wires attached to it?
Myron KY
11-14-2003 07:11:46
 Re: Re: Re: how to one wire a 1750? in reply to Big M, 11-13-2003 21:14:16
Yes, you can use the dark green wire as your one wire or you can run your own one wire up to the Amp gauge. The old voltage regulator can be removed. I believe there are other, needed, wires in that harness so it would have to stay or be modified.
There is one thing about the one wire alternator I forgot to mention. When the engine is off, the alternator will draw a small amount of current from the battery(s). If the tractor sets unused for long periods of time the battery(s) may get weak or fully drained.
Personally, I would run my own one wire to the Amp gauge and leave the old wires and regulator intact. That way I could go back to the old style alternator should I want or need to.
Good luck!
Myron KY
