what will it fit
Steve in ohio
11-10-2003 20:07:54
i know that olivers are pretty easy to adapt an engine to. we have a 372cu perkins diesel out of a combine that runs like a top that my dad and I were wondering what tractors it might fit in. there is a 1800 series b oliver with a blown engine that has hydrl shift at an auction at the end of the month. im no stranger to olivers as we have a 1750 that we use quite often. i realize we may have to do something about radiator and air cleaner and things such as that. but will the engine bolt up to a hydrol shift? or will i have to make an adaptor plate. how would i go about getting a clutch for it? would i use the one from the tractor im putting it in? im just tryin to figure out what i am looking at and such, let me know if im missing anything. thanks.
J. Schwiebert
11-12-2003 08:22:31
 Re: what will it fit in reply to Steve in ohio, 11-10-2003 20:07:54
The 372 engines were only ever used in Combines. Outside dimensions are the same as a 354.
Marc Smothers
11-11-2003 16:06:26
THere is a fellow in Ohio named Steve that I bought a 1755 from that put a 372 Perkins in an 1800. I can get you in touch with him if you want. Marc
steve in ohio
11-11-2003 17:33:00
 Re: Re: what will it fit in reply to Marc Smothers, 11-11-2003 16:06:26
yes if you would could you get ahold of him and mabey send him my way, thanks
Marc Smothers
11-11-2003 18:04:01
 Re: Re: Re: what will it fit in reply to steve in ohio, 11-11-2003 17:33:00
Email me and I'll see if he minds I give you his number.. Marc
Shep Va
11-11-2003 05:27:59
First let me say I know very little about the 371ci Perkins engine. I am assuming it is simular to the 354ci Perkins that was in the 1850 tractors. What I would try to do is to get some parts from the 1850 set up that ran a 354ci Perkins engine and try to adapt that to the 371ci Perkins, and then it will fit into the 1800.
If you can get the 354ci Perkins bellhousing to fit to tthe 372ci Perkins, you can get it to hook to the hydra power. I have one of these bell housings if you would like me to take pictures of it for you, or I would sell it if you need one. You will also need the tractor side bellhouing for the hydra power off of an 1850 diesel tractor.
You would likely use the engine clutch and flywheel, but you will have to have a way to put the PTO hub in the center of the flywheel. You may have to use a 354ci Perkins flywheel and clutch if you cannot get the PTO hub mounted. Here again I have those if you think they will work for you.
The tub frame will be the hardest part. You will need to get rid of the Waukesha mounts inside the tub frame, or get an 1850 diesel frame and switch frames. Either way you will need to custom fab the engine mounts somehow to make the engine level and fit in the frame. This may be the biggest challenge.
Then after you get the engine set and mounted and hooked to the hydra power, you can worry with the radiator and fan placement, radiator hoses, oil lines, intake and exhaust, and the rest of the install.
I think it is possible, but I have never done this engine before, so I cant say for sure. Drop me an email if you want and we can discuss further if you want.
Good luck
