S55 Gas: Air Filter
Francis
11-08-2003 19:46:46
I took the oil bath air cleaner assembly completely off for cleaning purposes and it's quite plugged up. Considering that the whole assembly has been knocked off a couple times (I didnt do it!), I'm thinking in putting a complete new device held with a custom made bracket so it would not stand too far out on the side. I dont mind if its not the original air cleaner... as long as it does the job. However I dont want to alter the metal sheets. Should I stick with the oil bath type of filter? Do I have to consider some specific parameters like air flow capacity/restriction to select the right device? How about the pipe lenght between filter outlet and carb?
Tks
Jd in da UP
11-10-2003 05:03:26
 Re: S55 Gas: Air Filter in reply to Francis, 11-08-2003 19:46:46
Stick with the oil bath, and the distance shouldn't make any difference, but I'm no expert..... ....
