Super 55 Zenith Carb
Bill
11-07-2003 15:32:46
The Super 55 I have has a Zenith Carb with 2 adjustments. The one is a screw on the top tilt back towards the driver. The other is on the bottem of the bowel with a rod and a roll pin for finger adjustment. This is the Carb that leaks gas when I try to start it. The carb has been removed and cleaned and it still leaks gas when I try to start it. It was running one day the next day the problem was ther when we tried to use it. What are the two adjustments for? Any more helpn the leak?
Larry from MD
11-07-2003 15:53:52
 Re: Super 55 Zenith Carb in reply to Bill, 11-07-2003 15:32:46
The one on the bottem is the power or high speed adjuster.The other is the idle and this is where it can get confusing.The old carbs really did regulate the flow of gas to the idle jet.Then zenith changed and this screw changes the air preasure to regulate the gas.So some zeniths you turn the screw in to reduce the flow of gas and on others you turn the screw out.
JD in da UP
11-10-2003 05:14:25
 Re: Re: Super 55 Zenith Carb in reply to Larry from MD, 11-07-2003 15:53:52
Your leak is probably related to your float and needle valve. Adjust the float properly and put in a fresh needle and seat. An inline fuel filter works wonders to prevent dirt holding the needle valve open a little. Good luck.
