Oliver 2150 injection pump turn up.
Isaac
11-06-2003 16:39:18
How do I turn up the injection pump in my 2150 Oliver to get the same power as a 2-155 White. My tractor is curently putting out 135 hp on the dyno with the stock settings, and I would like to get it up to at least 157 hp like the 2-155 White. Any suggestions on pump addjustment or mods. Possibly a different set of injectors or head on the pump. The engine and turbo feel strong. It has too much power for third gear and not enough for fourth when pulling in the 15500 pound class. It's curently turning about 2900 rpm's. Thanks for any help.
old
11-06-2003 19:17:05
 Re: Oliver 2150 injection pump turn up. in reply to Isaac, 11-06-2003 16:39:18
I believe that is some thing you would have to take to a pump shop. But if you did they can turn them up if I remember about 20%. They would also know other tricks to get your HP up. hope this helps
