Super 55 Carb gas leak
Bill
11-04-2003 19:53:47
The carb leaks gas only after attempting to start the tractor. Any ideas?
old
11-04-2003 20:56:42
 Re: Super 55 Carb gas leak in reply to Bill, 11-04-2003 19:53:47
You don't say if it starts so I'll figure it doesn't. Sounds like a main jet clog,which means that the gas doen't get atomized it just gets sucked up and then drops back down in to the choke area of the carb. Remove the drain plug at the bottom of the carb to see if that is clear, gas should flow out, next remove the main jet adjuster and crank the engine a little some times that will clean it up. But if it doesn't you will probably have to rebuild the carb. hope this helps
jake
11-05-2003 05:22:37
 Re: Re: Super 55 Carb gas leak in reply to old, 11-04-2003 20:56:42
Sounds like dirt in the carb, when blowing out the main jet remove the small brass screw next to the drain. Any particle stuck there will cause a no start also the gas inlet should be blown. These carbs are so simple there is hardly anything that can go bad but a little dirt screws it up big time.
