Which way is best to free a stuck engine?
Stuck engine?
11-02-2003 14:10:46
Reading through the posts I have found several ways to free a stuck engine. Which way is BEST.
Some say turpentine, others diesel, PB Blaster, Free All and kerosene. There has to be one that works better than the others.
Which is best, and why?
denjoe
11-06-2003 19:35:54
 Re: Which way is best to free a stuck engine? in reply to Stuck engine?, 11-02-2003 14:10:46
My uncle, now 83 and still farming who has bought and sold a hundred tractors and worn out as many, told me once "take out the plugs, pour transmission fluid in, and rock the rear wheels (in gear of course) everytime you walk by it. Works everytime".
Jerry
11-05-2003 05:56:09
If you have a tractor that is easy to get the pan off of pull the pan and unhook rods until you find the one or more that is tight. Almost never are all of the pistons tight. You may have to unhook them all but one and then start hooking back until you come to one that is tight. Pull the inserts out of the rod cap that is tight and wrap a strip of hard thin plastic around it and leave cap somewhat loose. Then put tractor in gear and rock until it comes loose or you get tired. If this method does not work at least you know which cylinder is tight. Also with this method you isolate the tight piston and then you need to try to pull is down instead of up, they almost always come down because the rust is on the top.
Nathan
11-04-2003 18:51:05
Probably almost everyone who responds to this message will have a different "miracle cure" for a stuck engine, and they will all swear that theirs is the best. I've also heard of Coca-Cola, Marvel Mystery Oil and Brake Fluid. Maybe you could loosen each connecting rod from the crank, try a different fluid in each cylinder, and see which one works best, then let us know.
The most important factors are time and patience. Try not to break anything in the process, especially if it's a rare engine or is hard to find parts for.
Good luck,
Nathan
