Oliver dozer
JimInOz
11-02-2003 12:17:38
Hi.Just took a quick look at an Oliver dozer from a distance.If I go for a closer look ,how will I identify the model?It has hyd blade,weighs about 10 ton,big winch on rear.I know a bit about other crawlers,but never seen large olivers.Thanks guys.
J. Schwiebert
11-02-2003 14:09:12
 Re: Oliver dozer in reply to JimInOz, 11-02-2003 12:17:38
Take a look at the engine. Diesel? How many cylinder heads? I would guess maybe OC-15 if it is that big. Should be a serial number tag on the machine that you can see from the seat. If it still has Cletrac on it the serial number tag will be on the fire wall by the fuel tang.
old
11-02-2003 12:44:01
take a look at cletrac.org Blake has a lot of pictures of them in that site hope this helps you some
