How to pull a stuck pto drive shaft in a 1855????
Bob
11-01-2003 20:04:53
Needing to pull the engine in my 1855. Majior work needs to be done. Well got the plug out the o ring and all, but damn it is tight in the. We already have the top off the trans and it seems to just be hung up at the flywheel. Any ideas as to how to get it to move. Slid hammer on the bolt in the end of the shaft????? ???
Thanks all
Steve
11-02-2003 05:20:10
 Re: How to pull a stuck pto drive shaft in a 1855? in reply to Bob, 11-01-2003 20:04:53
Screw a long 1/2" bolt with a nut into the shaft. Use the nut as a lock-nut, tighten it against the shaft. Use an impact wrench, set it on a low torque setting and try to tighten the bolt, while pulling back on the bolt. Works every time.
KZL
11-02-2003 00:33:12
Screw a piece of ready bolt into the shaft. Put a piece of flat iron through ready bolt and then a nut. Basically your making a puller.Tighten nut and this might get it started.
