white 2-155 hydraulics
whitehouse
11-01-2003 17:55:09
Just bought this tractor and first white ive owned .Hydraulics work but seems like they are full of air or pump is not getting enough oil.Ive bled them every way i know how but it doesnt seem to help.Ive also checked every place i know for a leak in the suction side of system and cant find any. Tractor had a new pump on it when I bought it.I have changed all the filters.Checked all the lines ,none crimped or colapsing.I dont think there is much wrong with tractor but just need a little direction on where to start looking for the problem. Any help would be greatly appreciated.
Wrenchbender
11-01-2003 19:01:51
 Re: white 2-155 hydraulics in reply to whitehouse, 11-01-2003 17:55:09
There is a charge pump located behind the main hyd. pump. It draws the oil from the the trans/diff. and charges the main pump. Remove the floorboard and the trans cover and you will see two large tubes. These have o-rings that seal them. The tubes are secured with a tab welded to them, I've seen this tab break off and let them come loose. WB.
