Industrial Super 88
Gary
11-01-2003 13:16:20
What is the easiest way to get calcium out off my rear tires? I have been to one are two tractor pull the frount end likes to come up before I lose traction.
Larry from MD
11-01-2003 16:54:48
 Re: Industrial Super 88 in reply to Gary, 11-01-2003 13:16:20
It depends how much you want to get out.You can remove the valve core and quickly slip a hose over the stem.Put the other end of the hose in a barrel(plastic).The preasure in the tire will push alot of it into the barrel.Add more air as needed.If you only need to go down 500 pounds this will work with 2 large tires.A good jack under the tractor can be used too.
old
11-01-2003 15:57:05
go to your parts store or tractor dealer and get an adaptor for the tube then buy a drill pump hook that up and pump it in to a 55 gallion drum make sure that the valve is at the bottom thats how I do it both filling and emptying hope this helps you
