starter starts on its own
Joe
10-31-2003 06:26:19
I have a 1365, yesterday I parked it and walked away. a few minutes later I hear the starter motor running (not turning the engine over just free spinning). I had to disconnect the battery to get it to stop. the key was off, the starter switch was in the off position, and the tractor was in gear. after it sat for a couple of minutes I hooked the battery back up and everything was back to normal. any ideas on what caused this? I don't want this to happen when I am not around to hear it.
Mark
11-02-2003 16:18:29
 Re: starter starts on its own in reply to Joe, 10-31-2003 06:26:19
I have had that happen on two different tractors, One was in the regulator when the points click shut it would short internally and back feed to the starter. The other was a short in the starter relay.
Richard
11-01-2003 04:36:01
I don't know what to tell you but I have the same problem with my Ford 3000 diesel. I had to pull the cable to get my to stop too. Today I have to pull the starter out and see what is wrong. My is out in the field so I have to tow it into the barn because there is no starting it when this occurs. This is the first time I have ever had this happen. I suspect there is a short in the starter. Maybe it is haunted(yesterday was Halloween).Ha!
Dean Barker
10-31-2003 22:52:50
The White 4-150 tractors had that problem; I think it was a Delco starter. BA Starr probably remembers the solution to that one.
RockinB
10-31-2003 20:58:54
Maybe its haunted.
old
10-31-2003 10:18:37
sounds like a bad wire some place 2 ways to fix it is look for and find the bad wire/switch or put a disconnect in the battery cable hope this helps some I know it doesn't say much
