550 Oliver
Mark
10-28-2003 14:27:56
I have a 550 Oliver that will not stop getting jambed between gears. I took the seat and plate off to get to the gearing. What I discovered was that both shifters were "between gears" and in effect jambing each other. I put them back in neutral, reassembled the old girl and drove her down the driveway. Only to stop, depress the clutch and shift gears. Jambed again! Help!
Thanks, Mark in Michigan
R. Marg
10-28-2003 15:54:30
 Re: 550 Oliver in reply to Mark, 10-28-2003 14:27:56
sound like you need to ask Larry at olivertractor.com he will know what is up
Alvin n Ms.
10-29-2003 15:41:53
 Re: Re: 550 Oliver in reply to R. Marg, 10-28-2003 15:54:30
I own a 35MF that does that. I take the filler plug out, then insert a long screwdriver, to move the gears around. Lots of old tractors do that because of wear. Try shifting slowly and don't take short cuts when shifting.
