HG-42
SHAWN
10-27-2003 06:14:34
Was wondering if anyone could tell me the belt and drawbar hp of this model. Ours is a 1950 model.
Rose
10-27-2003 19:40:09
 Re: HG-42 in reply to SHAWN, 10-27-2003 06:14:34
HG Crawler Cat is 25 hp.
R. Marg
10-27-2003 08:02:04
try cletrac.org Blake could tell you all you want to know about it
ajax implement
10-27-2003 06:20:59
1950 is also the year they went from the 3.125 bore IXK engine to the little larger (3.250 bore) IXB engine. There was also more than One Test on the HG. If you have the late one also check out the OC-3 which also uses the IXB engine and is 95% the same tractor. I think both engine ran the same RPM.
Dave Grubb
10-27-2003 11:07:41
 Re: Re: HG-42 in reply to ajax implement, 10-27-2003 06:20:59
I have seen various ratings on the IXB-3 engine but I believe the most accurate is 16.9 taxable (NACC) and 25.4 rated at 1500 RPM.
