oil on plgs
peter
10-26-2003 12:24:50
recently bought an oliver770, thinking i was getting a good deal, i got it home and got it running after sitting 5 years but didnt run good , i had avalve job done (everything) rewired, rebuilt carb, complete tune-up, new alt., i have it running pretty good but it burns oil badly not under load, runs better under load and doesnt seem to run badly under load at all. is it wishful thinking of me to think as time goes buy it will start to run better or should i plan new rings? p.s. had good compression. what should i do ????? ????? ????? ??? peter in michigan thanks in advance, needs choke to start
RAB
10-27-2003 00:20:27
 Re: oil on plgs in reply to peter, 10-26-2003 12:24:50
When you say you had a valve job done, do you mean the guides as well? Oil could be finding it's way down the inlets especially at high vacuum conditions (are there seals on these valve stems?). If the compression is OK and you are not burning oil like crazy it may have glazed bores and need some proper hard work to bed things down. If your diagnosis is on plug colour alone, try a grade hotter plug, especially if you are not working it hard and check the engine temperature - it may be running too cool. If it is running on non detergent oil, rings may be gummed up, but I will not get into advising an oil type change - there is enough information on the archives to keep you busy for an evening or two! So my advice is find out what is actually happening or you may finish up wasting time and money.
Regards, RAB
Brad
10-26-2003 13:04:41
It may just have stuck rings that may loosen up over time. I have heard of people installing a pertronix electronic ignition, hot coil, and good plug wires to help keep the oil burned off the plugs.
RWT
10-26-2003 20:11:34
 Re: Re: oil on plgs in reply to Brad, 10-26-2003 13:04:41
I can't resist. As crude as they are the anti-foulers seem to work at least in some cases. They are also are something cheaper to try first and I am reasonably sure they make them in that style of plug.
If this were mine though I would have to tear it back down.
RT
