550 thru 570 Cockshutts?
Troy
10-25-2003 18:55:09
Are the chasis the same between models? Will a six cyl bolt in place of the four cyl?
Phil Heisey-Harleysville,
10-26-2003 03:52:16
 Re: 550 thru 570 Cockshutts? in reply to Troy, 10-25-2003 18:55:09
Troy,
The trans. and rear end on the Cockshutt 560 ,570, & 570Super are different and heavier than the 550. The heavy cast front engine tub frame is also the same on the above tractors and different than the 550.
I hope this helps. I have many Cockshutt parts and can assist with your info./parts needs.
Phil Heisey 215-256-8651
