770 gas overhaul tips please.
Gary
10-23-2003 15:37:45
I am getting ready to open up a friends 770 which runs great but has a real faint knock! does not seem to be rods or mains but we are going in! I am thinking wrist pins! also where has been a great place for engine kits. all that is known is tisco! is it ok to hone out the sleeves?
J. Schwiebert
10-25-2003 15:52:56
 Re: 770 gas overhaul tips please. in reply to Gary, 10-23-2003 15:37:45
Lets get some fundamentals straight. The engine has offset rods so mark them as three go in one way three the other. Also remember they are not pressure lubricated. Second thing you asked about honing. That can not be answered until you scope out the taper and out of round in the cylinders. If out of round or tapered too much you will need a sleeve kit. I would go 3.625 diameter sleeves then . It would make it the same size as a 1550 engine. If you do hone, wash the sleeves with good warm soapy water, dry the sleeves and coat with oil. Also pull the sleeves and install new O-rings. Questions find me on the Oliver-Hart Parr site.
R. Marg
10-23-2003 16:01:31
e-mail me and I can give you a phone number for a place that has what you want
Brad
10-23-2003 17:45:11
 Re: Re: 770 gas overhaul tips please. in reply to R. Marg, 10-23-2003 16:01:31
We stock anything you should need
Maibach Tractor 1-800-808-9934
