oliver 2455 info
zoidberg
10-18-2003 06:51:57
Has anyone any information about the 2455? I did't even know this model was in existence and therefore know nothing about it. What does everyone else know? Thanks for the comments
J. Garms
10-18-2003 09:51:27
 Re: oliver 2455 info in reply to zoidberg, 10-18-2003 06:51:57
The 2455 was the early 2655, 2455 had a smaller motor and the available cab was different. Both machines are Molines painted green, also found in red called a White Plainsman. The MM numbers where A4T-1400 and A4T-1600. Because MM used parts from the shelf, many components are inter-changeable with other big Molines. The planitary rearends from a big two-wheel MM will bolt into the these tractors, and MM made a 800ci stationary motor that also bolts in. The big MM motor in these 4-wheelers where notorious for blowing when people turned them up (not getting enough oil to the mains?) Many have been repowered with cummins, but someone is making an after market kit that get more oil to the mains.
Frank Dodsond
10-18-2003 08:06:47
According to Larry Gays book A GUIDE TO HART-PARR, OLIVER AND WHITEFARM TRACTORS 1901-1996 the 2455 was marketed as the White Oliver during 1969-70. It was a 4WD articulated steering model. It was actually built by MM. It had 504 ci 6 cyl MM engine producing 139 hp. This tractor was not tested in Nebraska. You might say that the only thing Oliver were the decals and paint.
Brad
10-18-2003 08:12:41
 Re: Re: oliver 2455 info in reply to Frank Dodsond, 10-18-2003 08:06:47
In the pictures I have seen, the have a LP tank and no cab, is this how all of them were produced?
J. Schwiebert
10-18-2003 08:52:03
 Re: Re: Re: oliver 2455 info in reply to Brad, 10-18-2003 08:12:41
Brad: We sold two of them and they were red. They were both diesel with M & W turbo's from the factory. They were available before the A4T 1600 and they involved a seperate contract to sell them. A cab was put on one of them later and then later than that it got a Cummins and about 3 years ago was traded on a late Massy and it let the area.
Brad
10-18-2003 11:49:05
 Re: Re: Re: Re: oliver 2455 info in reply to J. Schwiebert, 10-18-2003 08:52:03
They used the 504, didn't they?
J. Schwiebert
10-19-2003 03:54:22
 Re: Re: Re: Re: Re: oliver 2455 info in reply to Brad, 10-18-2003 11:49:05
Yes
IanC
10-19-2003 18:48:31
 Re: Re: Re: Re: Re: Re: oliver 2455 info in reply to J. Schwiebert, 10-19-2003 03:54:22
We had a 2655 come in with a turbo on it. It's listed in the parts book as an "altitude compensator", and what little research I did when we worked on the thing, it was supposed to be sold at only higher elevations.
