power beyond for 1655
Jake in NY
10-17-2003 20:33:35
third party image
OK, we want to set up a power beyond to run the loader on the 1655 but aren't quite sure what we're supposed to hook up to. I took this picture and if anyone could tell me what does what I would greatly appreciate it.
This is the first time I have tried to put in an image in a post so we will see if I did it right.
Thanks, Jake
Myron KY
10-18-2003 06:37:37
 Re: power beyond for 1655 in reply to Jake in NY, 10-17-2003 20:33:35
Jake,
For some reason Geocities.com won't let you link to a picture. It wasn't anything you did wrong. Shep VA has the same problem.
Here is a picture of the Power Beyond ports on my 1850. I think they are about the same as your 1655 but Brad or someone will have to verify that. The terms inlet, bypass and exhaust refer to the ports on your remote valve. In case you didn't know this is an open center system and will require an open center valve. Hope this helps.
Myron KY
third party image
Brad
10-18-2003 08:07:55
 Re: Re: power beyond for 1655 in reply to Myron KY, 10-18-2003 06:37:37
Yes, the 1850 and 1655 are the same in that aspect.
Myron KY
10-18-2003 09:27:59
 Re: Re: Re: power beyond for 1655 in reply to Brad, 10-18-2003 08:07:55
Thanks Brad. I had suspected they were but wasn't sure.
Jake, I have that page, of the Service manual, scanned and can send it to you. It's too large to post here. E-mail me at the above address ( remove the X1 ) if you would like to have it.
Myron KY
Brad
10-17-2003 23:21:53
I'm going by memory on this, but the "tank" outlet from the valve just goes into the unit's return, a plug on the lower center of the left side of the unit, I believe there is a 3/4 pipe plug there now. On the left front corner of the top cover that holds the spools there is a plug on the side and one on the front. you take the front one out (I think it is 3/8 pipe) and and put a 1/4 inch allen head pipe plug back ito the hole, there is threads back in a couple of inches. the one on the front and the one on the side is where you put the pressure and BYD lines, thoug I don't remember which is which. I will get back on this.
